NWOleman Posted January 13, 2008 Report Share Posted January 13, 2008 Alright i finally got my hands on a 20L with the long 5 speed! I pumped! Its got the 32/36 weber with a header. Here's the plan, SUPERCHARGER! I plan on buildind a manifold out of Stainless Steel and buying like a Eaton M90 or M 45 off ebay. Then run a Holly 350 cfm carb. Comments, suggestions, please give it to me, I can handle the truth! Thanks NWO Quote Link to comment
NWOleman Posted January 13, 2008 Author Report Share Posted January 13, 2008 Also i got the SSS 219 head so that will help with power. I already have a bigger electric fuel pump that im going to use that will be more than enuf. I plan on getting the header jet coated. Then put in a aluminum radiator out of a VW. Will the stock rods and pistons hold up? Im not planning on running lots of boost but i want to make over 200 hp and 250 would be great. Thanks guys, NWOleman. Quote Link to comment
Cruzn620 Posted January 13, 2008 Report Share Posted January 13, 2008 well, considering that a FAST L20 is like 120-130hp, i think if you are shooting for 200-250 you need to be looking at your bottom end. I'm not saying its not possible, because anything is possible, but if i remember my ears correctly, there are only a couple of L20's making 200hp and being streetable. I know over in australia somebody built a drift car using an L20 block and they are making like 700HP, so like i said, any thing is possible, but it may not be as easy as you are thinking. you better post lots of pics though because this will be one heck of a build!! Quote Link to comment
