Stitebunny Posted October 4, 2010 Report Share Posted October 4, 2010 I'm looking for the brackets to run either a throttle cable or throttle shaft from the firewall. I don't have any of them. I need the rounded one that mounts on the carb throttle shaft and the bracket that supports the cable or the stock 510 throttle shaft that comes out from the firewall and the bracket that mounts to the carb throttle shaft. If you have any of them I would appreciate the help. Hoping to trade for some parts I may have that you need. Thanks, Chris Link to comment
H5WAGON Posted October 4, 2010 Report Share Posted October 4, 2010 I'm looking for the brackets to run either a throttle cable or throttle shaft from the firewall. I don't have any of them. I need the rounded one that mounts on the carb throttle shaft and the bracket that supports the cable or the stock 510 throttle shaft that comes out from the firewall and the bracket that mounts to the carb throttle shaft. If you have any of them I would appreciate the help. Hoping to trade for some parts I may have that you need. Thanks, Chris I have an extra stock setup....:rolleyes: Link to comment
