Pineapplegti Posted September 28, 2010 Report Share Posted September 28, 2010 Does any one have a collasped and extended measurement of the popular rear 510 coilovers ? Quote Link to comment
dennis Posted September 28, 2010 Report Share Posted September 28, 2010 Here are some QA1's that will work dr8855p 13" collapsed I just ordered some AFCO coil over bodies with similar measurements. Quote Link to comment
Pineapplegti Posted September 28, 2010 Author Report Share Posted September 28, 2010 Thanks Dennis..thads exactly what I'm after.. Quote Link to comment
dennis Posted September 28, 2010 Report Share Posted September 28, 2010 Thanks Dennis..thads exactly what I'm after.. This is from Dave Patten. I used the same spring but at 250lbs. DR7855P $140.00 each (Shock P/N, "P" is for poly bushings not rod ends, shocks are 12 way adjustable w/compression and rebound in one knob so both adjust together, coil over spring mounts are included in the cost) SS110SDM $25.00 each (This is the conversion kit to change from eye to stud at top.) 14CS200 $45.00 (QA1 coil over springs, 14" free height, 200# rate, 2.5" ID) Quote Link to comment
dennis Posted September 28, 2010 Report Share Posted September 28, 2010 sorry double post Quote Link to comment
Pineapplegti Posted September 28, 2010 Author Report Share Posted September 28, 2010 What afco shock did you end up going with ? Quote Link to comment
dennis Posted September 29, 2010 Report Share Posted September 29, 2010 I went with a AFCO T2 the measurements are 12.9" Comp, 18.9" Ext 6" stroke The T2's are double adjustables Quote Link to comment
