tjyak50 Posted August 29, 2010 Report Share Posted August 29, 2010 I wasted the entire day scouring Phoenix, AZ for rubber hole plugs / grommets for the 240z Is there a secret supply? Quote Link to comment
izzo Posted August 29, 2010 Report Share Posted August 29, 2010 Probably the same as the 510s? Check summit racing, if you know the diameter buy some new ones they should be cheap. Quote Link to comment
tjyak50 Posted August 29, 2010 Author Report Share Posted August 29, 2010 Prolly are. $10 each at Summit - wow. I might just cut some rubber and use Seam Sealer to goop it all down. Quote Link to comment
izzo Posted August 29, 2010 Report Share Posted August 29, 2010 Prolly are. $10 each at Summit - wow. I might just cut some rubber and use Seam Sealer to goop it all down. Holy crap man, 10 bucks a plug is expensive. Let this thread go for a while maybe someone else has a better answer, if i had spares i would hook you up but i dont Quote Link to comment
tjyak50 Posted August 29, 2010 Author Report Share Posted August 29, 2010 Ya gotta be careful when searching the internet for "Rubber Plugs" or 'BUTTon PLUGS"... After a messy diversion, I did find this: http://www.restorati...log%20ebook.pdf Even better? http://www.nutsandbo...html#googlebase Quote Link to comment
izzo Posted August 29, 2010 Report Share Posted August 29, 2010 Ya gotta be careful when searching the internet for "Rubber Plugs" or 'BUTTon PLUGS"... After a messy diversion, I did find this: http://www.restorati...log%20ebook.pdf Even better? http://www.nutsandbo...html#googlebase :rofl: yes you do Quote Link to comment
MicroMachinery Posted August 29, 2010 Report Share Posted August 29, 2010 If you get the dimensions, you can probably shuffle on down to your local napa and get em for $.40 a piece. Quote Link to comment
