Blknight692 Posted July 6, 2010 Report Share Posted July 6, 2010 I have a '71 521 with a 2bbl EMPI 32/36 that has me baffled. Had some issues with the carb being loose on the intake so I took it all off and tightned down all the adapters off of te intake. While i had it off I decided to give it a good clean up with some carb/choke cleaner. As soon as I got looking into it, I noticed that the interior barrel looked alot more dirtier than the external. Didn't give it a though, cleaned it up and put everything back on. Runs fine, but then I remembered the exterior barrel being so clean. So I started it up and started going over it. I put my hand over the exterior barrel and it didn't do anything, hardly any suction at all. Put my hand over the interior/dirty side and it choked out the motor. WTH? The more i get into this little rig the more mods I'm finding, but does it only use 1 barrel of the carb? Quote Link to comment
banzai510(hainz) Posted July 6, 2010 Report Share Posted July 6, 2010 runs off main barrel untill the mechanical 2nd opens up the other barrel. if its running dont worry about it Empi is a chinese clone of the weber DGV right? olddatsuns.com is your friend!!!!!!!!! Quote Link to comment
Blknight692 Posted July 6, 2010 Author Report Share Posted July 6, 2010 So basically it acts like a 4bbl with the second being the secondaries, gosh, that makes sense, lol. Yeah, the EMPI is a cheap knock off of the Weber. When I say cheap, I mean cheap! Thanks! Quote Link to comment
