Free 720 ST Steering Wheel for Locals Ratsuners!
  • Replies 5
You can blame Nissan for the loc-tite. :( Getting loctite hot helps a lot to get stuck bolt loose. Remove the two screws that hold the black plastic on, you can see these in the second pic. Then warm that bolt area up with a lighter for a while, also try beating a small torx bit into the stripped allen hole.
Good luck
