Dat620 77' Posted December 10, 2007 Report Share Posted December 10, 2007 Looking for a weber Carburator with everything to install it with addapter plate everything and looking for dash and dash faceplate mine is broke i also need the steering wheel pieces where the ignition goes thanks. Link to comment
lancekilgore Posted December 11, 2007 Report Share Posted December 11, 2007 I have a dash face plate but instead of the radio it has the ac vents in it, and are you looking for the casing that cove the ignition and such? Lance Link to comment
650savag Posted December 22, 2007 Report Share Posted December 22, 2007 Lance, Did you find the steering wheel pieces that you need? I found a 77 KC here in my small town (4,000) just a couple of days ago and it's being parted out. shame too, cause the body on it is really nice and straight. Anyway, I needed a driveshaft cause I let a u-joint go bad for too long on my 78 and it came apart going down the road last Sat. The front u-joint came apart and ruined the front shaft. Thanks goodness, it did not ruin the tranny. I got it back going yesterday. It's the same one that I put the rebuilt carb on that I got from you the other day. I can check on the 77 and see if the steering wheel pieces are still good if you want me to. It's an auto tranny and L20B. Most everything is still on it (except for the driveshafts). Let me know if you want me to check. The truck is less than a mile from my house. He's also got a 81 720, reg. cab that he is parting out. I'm 650savag over here. Dan Link to comment
lancekilgore Posted December 22, 2007 Report Share Posted December 22, 2007 No iwas not looking for any steering wheel stuff, is it a short bed or long for the drive shaft? I guess I will go in and see isf I can find one for you todayonly the short right? Lance Link to comment
650savag Posted December 22, 2007 Report Share Posted December 22, 2007 Lance, I don't need the shaft now. I got the entire shaft from the 77 KC that I found here in town. I only used the short shaft, do I still have the long one with good working u-joints if anyone needs it. I thought from the original thread here that you wre needing some steering wheel parts. The Hitachi carb i got from you is still doing good. Thanks, Dan Link to comment
lancekilgore Posted December 22, 2007 Report Share Posted December 22, 2007 That is a ballance unit I would use the whole new one or it will be out of ballance. I will take the short one I got today for you back. Lance Link to comment
650savag Posted December 22, 2007 Report Share Posted December 22, 2007 Lance, I'm sorry about the mix up. I thought you would have read the other posts about the driveshaft and knew that I had already gotten it repaired. Let me know if you need anything off the 77 KC, auto tranny ,here at the local J/Y. Thanks, Dan Link to comment
freaky510 Posted December 23, 2007 Report Share Posted December 23, 2007 i have 2 working carbs i believe we spoke before pm with an offer. Link to comment
