Kevin S. Posted May 10, 2010 Report Share Posted May 10, 2010 Hello all I am a newbe here and just got my first 620.... I am having trouble trying to figure out what I need to measure to get the right center support bearing for my driveline. There are two different sizes and I don't have a clue what or were I need to measure to find out which one I need. All I know is that mine is HAMMERED!!!!! Any help or pics would be AWESOME!! Thanks! Quote Link to comment
datzenmike Posted May 10, 2010 Report Share Posted May 10, 2010 The actual bearing seldom goes bad. What happens is the rubber ring around it rots off allowing the shaft to wobble around. I've fixed this by removing the metal strap bolted around it and wrapping the shaft with a strip of rubber and clamping the strap back down to hold in place. Worked so well that I left it. Quote Link to comment
Kevin S. Posted May 11, 2010 Author Report Share Posted May 11, 2010 The actual bearing seldom goes bad. What happens is the rubber ring around it rots off allowing the shaft to wobble around. I've fixed this by removing the metal strap bolted around it and wrapping the shaft with a strip of rubber and clamping the strap back down to hold in place. Worked so well that I left it. That is a great idea. I never thought of that..... Some rubber belting would probably work great!! Thanks for the quick reply!! Quote Link to comment
