Str8_69 Posted May 4, 2010 Report Share Posted May 4, 2010 In good shape, mine been water logged and wont hold stickum for the vinyl. PDX area. Also looking for antenna. Link to comment
dat620 Posted May 5, 2010 Report Share Posted May 5, 2010 i have 2 good sets, 1 black set, 1 blue set, i will sell complete sets only, i am asking 60.00 per set plus shipping, thx tom Link to comment
mr68gts Posted May 6, 2010 Report Share Posted May 6, 2010 For what year 620? The doors are the same except for the holes for the panels and the panels are shorter for the earlier models height wise. If you have earlier doors, use the earlier panels. The panels have a strip of metal screwed into the top at the door. then the panel slides up into it and clips in else where. The later doors have the reliefs for the strips, but no holes. You can drill them but the reliefs aren't deep enough to install the strips i think. I do not know when they changed over to the 1 piece taller panels. Paul. Late style door. this door is on my 76. Early style door uses this strip. This is off my 73. Strip bolts to where the primer is in the door. Those reliefs are in later doors, but not deep enough. This is the on my 73 Link to comment
