mswit209 Posted April 18, 2010 Report Share Posted April 18, 2010 my rear crossmember bushings are completly gone now i came around a s curve and started sliding like mad right towards a bicyclist. i dont want to do the savage washer trick. but will if i have to. i have searched and searched and cant seem to find any rear crossmember bushings anywhere. does anybody have any idea were i can get some at a reasonable price compared to datsports 150.00 price. Quote Link to comment
sssr20det510 Posted April 18, 2010 Report Share Posted April 18, 2010 Did you try nissan? Don't know if they are nla or not Quote Link to comment
mswit209 Posted April 18, 2010 Author Report Share Posted April 18, 2010 yeah they are discontinued i work at a shop and we get fat discounts from nissan so that was the first place haha just ordered a speedo gear from them. coming from japan on backorder and about 16 bucks Quote Link to comment
sssr20det510 Posted April 18, 2010 Report Share Posted April 18, 2010 try nissan parts cc they check every dealership i found my 69 front valance through them it was at a chevy dealer that bought out a nissan dealership Quote Link to comment
mswit209 Posted April 18, 2010 Author Report Share Posted April 18, 2010 yeah i could but that would just be back to the stock rubber i wouldnt mind poly or even solid. Quote Link to comment
sssr20det510 Posted April 18, 2010 Report Share Posted April 18, 2010 did you try Maddat im sure they have them not sure if they will be cheaper than datsport Quote Link to comment
3nickels Posted April 18, 2010 Report Share Posted April 18, 2010 These bushings work great!! http://www.racetep.com/datsunsusp.html Or you could use the sold bushings if you don't mind the noise. http://designproductsracing.com/510_RearSuspension.html Quote Link to comment
mswit209 Posted April 25, 2010 Author Report Share Posted April 25, 2010 going with design products we will see how they work. im not worried about noise... it cant be worse then what i have now with how bad my bushings are. its like a slap in the ass every time i shift. Quote Link to comment
Yakuza Posted April 25, 2010 Report Share Posted April 25, 2010 DPR has GREAT products...I have a lot of His(Don/DPR) parts on my cars... :D Quote Link to comment
mswit209 Posted April 27, 2010 Author Report Share Posted April 27, 2010 i have the camber plates up front and like them quite a bit so im expecting this to be good quality too. Quote Link to comment
mswit209 Posted May 9, 2010 Author Report Share Posted May 9, 2010 well got the subframe bushing a while ago and just recently had time to put them on and they feel great. a little bit of noise and vibration in the cab but i think i might have a solution for that. ill test it when i do my diff bushings and ill try my idea then. i was thinking about taking the stock washer that goes on top of the subframe originally and fliping it and putting it back on. it will lower the front of the cross member a little bit but not enough to affect anything. that washer on one side has a rubber surface and im thinking that it may insulate it just enough to take quite a bit of noise out of the cab. on a side note... i kept reading up on how people removed the stock bushing. aall i found was people that burned them out then hacksawed the sleeve. well i found another way that works great. you take a 2 jaw puller and hook the jaws to the outer edges of the cross member. find a suitable plate that is just a hair smaller then the diameter of the bushing. then put a socket on top of that for a spacer. and finally use the puller as a pusher. it took me all of about 10 secs to take out one bushing. might take you a little longer if you dont have air tools. i did this trick originally with my rear a arm bushings. Quote Link to comment
3nickels Posted May 9, 2010 Report Share Posted May 9, 2010 Nice tech tip! Sure beats smelling that rubber as your trying to burn it out of there... :blink: Quote Link to comment
mswit209 Posted May 9, 2010 Author Report Share Posted May 9, 2010 yeah and it sure is a lot faster too. when i do my diff bushings ill use the same technique and try and post some pics as well... im bad about that i just want it done i dont like stopping to take pictures. but ill try to remember. Quote Link to comment
moath Posted May 10, 2010 Report Share Posted May 10, 2010 An air hammer should work well for the crossmember bushings as well. Quote Link to comment
