Weber 32/36 looking for one...
  • Replies 6
Need a 32/36 weber for my 620, in search of a used one. If I can not find one here well I guess I will be force to buy a new one.
Thanks
Best to get a new one that is an exact replacement for your truck. Failing that you may have to exchange jets to 'tune' it for best running/economy. Try to get an auto choke and an idle cut solenoid. If you have the L20B an idle cut is almost mandatory to prevent run on when shutting the motor off.
