pucancakes Posted April 11, 2010 Report Share Posted April 11, 2010 for those that put one on what did u use? did u take it from a 510, 240sx, 300zx, rx7, etc? im trying to find to pick one so i can still use low offset wheels . any help/info/input would be appreciated. thanks! Quote Link to comment
datzenmike Posted April 11, 2010 Report Share Posted April 11, 2010 Well what are the end results going to be used for? If drifting (shudder) stick with the H-190. Way easier to break loose. If racing, like auto-X, where handling is required then IRS away. If just to do it because you can then any IRS will do. If expecting to run a larger motor, skip the lighter 510 and run the 240sx. Quote Link to comment
pucancakes Posted April 11, 2010 Author Report Share Posted April 11, 2010 no crazy driving with the 520 just wanting to put one in ever since i had my last truck. i like the look when a truck is aired out and all 4 wheels are cambered in. should i look for one w an lsd? Quote Link to comment
