maximo Posted March 10, 2010 Report Share Posted March 10, 2010 Ok so I check the firewall cause I thought it was the most obvious place where water would leak, but to my surprise the water is coming from the driver side where the seat belt hooks up, right behind the driver seat. The only thing that I can think of is that water is going thru the fender and somehow running all the way back to where the seat belt bolts down. Any help please, suggestions with obvious places where you guys had to patch in order to keep water out. Next time I'll try to put pictures up thanx. Quote Link to comment
Guest DatsuNoob Posted March 10, 2010 Report Share Posted March 10, 2010 620 fenders exposed to wet weather almost always rot out in the area aft of the tire. Get some thick piant (por-15) and some rubber undercoating and coat the inside of the fender. Check drain areas on the side of the cowl behind the fender for blockage. Get some strip caulk and chase leaks if necessary, Good luck Quote Link to comment
hang_510 Posted March 10, 2010 Report Share Posted March 10, 2010 punctuation! or ill suggest pulling the rubber plugs and driving through puddles, to "help get water in the cabin" ;) Quote Link to comment
metalmonkey47 Posted March 16, 2010 Report Share Posted March 16, 2010 ...pulling the rubber plugs and driving through puddles, to "help get water in the cabin" ;) Quote Link to comment
