banzai510(hainz) Posted February 21, 2010 Report Share Posted February 21, 2010 I had some water dissapearing on my 521 for a few weeks. So I figured it was the head gasket. I swapt the head gasket using the timming chain tool I got from Shucks. Well after a few hours I replace the head w/a U67 head I had with a Scheider 460lift 260 dur cam. I forgot to mark the chain before pulling it off by any way I put the new head on there. Everthing seems fine and truck started right up. But noticed the power wasnt quet there. So today I adjust the speocket. Seems that when at TDC the links almost lined up at top so I figure the bottom one was on but was a tooth off at top. Well I lined the brite link on the dimple of #2 pos. So i will run it and see what happens. It was just luck the the brite link showd up as it take a few turns b4 they line them selves up again. But going by just using the TDC on crank and the dash and V notch it was almost always just right of the dash or just left of the dash(but very much under it) it just wasnt right on. So I figured Ill go by the timming links on chain this time. I adjusted sprocket to day see what happens 2 morrow. go to Kragon to order these timming chain tools. I got 4 http://www.kragen.com/productdetail.aspx?MfrCode=PBI&MfrPartNumber=648831&CategoryCode=3491 Quote Link to comment
banzai510(hainz) Posted February 22, 2010 Author Report Share Posted February 22, 2010 I swapped the sprocket still top end cuts out otherwise most peopl will never know. Im thinking now if you want a bigger cam then dont waist your money unless you get sidedrafts!!!!!! I think I got to get a bigger idle jet and maybe new fuel filter. Maybe my loss of top end power? Ill updats later. I finally used that tool and was EZ. Only prople peopl might encounter is putting the cahin back its hard to get the sprocket back on. I noticed if you rotate the cam slight left or right. (depending if you have to retard or adv.) it will put a cunt hair slack in the oppisite side for you to get the chain up. just use a big adj wrench on the center cam bosses to move cam left or right. fuel pump has to be removed for the ones that havent done this. 1 Quote Link to comment
Buzzbomb Posted February 24, 2010 Report Share Posted February 24, 2010 I swapped the sprocket still top end cuts out otherwise most peopl will never know. Im thinking now if you want a bigger cam then dont waist your money unless you get sidedrafts!!!!!! I think I got to get a bigger idle jet and maybe new fuel filter. Maybe my loss of top end power? Ill updats later. I finally used that tool and was EZ. Only prople peopl might encounter is putting the cahin back its hard to get the sprocket back on. I noticed if you rotate the cam slight left or right. (depending if you have to retard or adv.) it will put a cunt hair slack in the oppisite side for you to get the chain up. just use a big adj wrench on the center cam bosses to move cam left or right. fuel pump has to be removed for the ones that havent done this. When I did my head gasket with that tool, I had a helper push down on it while I took all the loose chain and threaded it back on the sprocket until my marks lined up. Then I sort of swung it up and over to the cam and bolted it right on. I know this sort of job is old hat for the L-Motor God :cool: , but maybe someone else will read this thread and can use that tip. I was lucky like you were; my marks somehow lined up the way they should when the whole chain is swapped out :o . For the money, that tool is really worth it. There are a few tools that are worth buying that lay in the tool box until you need it, and if you have a Datsun L motor, that tool is one of them, IMHO. Quote Link to comment
banzai510(hainz) Posted February 24, 2010 Author Report Share Posted February 24, 2010 Yeah I might have to pull the sprocket again and ajust cam timming. I think this head is running alot more air. It still cuts out when the 2nd barrel is engaging near the top end. but when it cuts out If I pull the choke it runs better so I need to do soem jet change or another carb change. Before when this set up(head & cam) was on a L16 it was fine with a 32/36DGAV I had and a 38/38. So maybe this 32/36DGV 5A is jetted differently. I will figure it out. Anybody run a DGV with a cammed motor and have a suggested main jet setting on the 2nd barrel?Esp the 2nd barrel. Hang 510? Anybody? My idle is really rough and went for a 50 to 60 idle jet but didnt really make a differece. I could swap my 38/38 on there then Im sure Ill know if its a jetting issue Quote Link to comment
banzai510(hainz) Posted February 27, 2010 Author Report Share Posted February 27, 2010 swapped back to #1 spocket position and will put the 3/38/38 on taday and see what happens. I think its now a jetting issue I like imtb's write up on those new Motorcycle Mikunis as a SU replacement. update later Quote Link to comment
banzai510(hainz) Posted March 1, 2010 Author Report Share Posted March 1, 2010 Adjust sprocket to #1 threw 38/38 DGES on and it runs like a great right off idle. Maybe Ill get some smaller idle jets (rought idle)But I have to say why more ppeople dont get 38/38s is beyound me(at least for a L20). Noticebale power increase. Quote Link to comment
