Datsun Parts Posted February 6, 2010 Report Share Posted February 6, 2010 The battery will die over night if I have the headlight fuse in, if not then its fine. I also noticed that the HEADLIGHTS WORK FINE without the fuse? Also, the alternator will not charge unless the fuse is in? What the hell, the loom is pretty much stock and uncut. I did add a new fuse block could it be bad? Quote Link to comment
datzenmike Posted February 6, 2010 Report Share Posted February 6, 2010 The headlight fuse has power to it at all times and only supplies the headlight switch. This means that something has been added to this circuit. There is also a second fuse that does the same for the parking and marker lights. Quote Link to comment
