thisisthenewsic Posted February 4, 2010 Report Share Posted February 4, 2010 hey. i got my 73 datsun 510 which the stock calipers are toast. i could replace calipers with stock for about 100$ from autozone. i already have s13 coilovers welded onto 510 spindles. so i need a brake upgrade to work with these. what is there out there that works with the 510 spindle not the 280z setup. Quote Link to comment
ichorid Posted February 4, 2010 Report Share Posted February 4, 2010 http://www.ermish-racing.com/510/brakes.html contact troy. I bet he can set you straight. Quote Link to comment
INDY510 Posted February 4, 2010 Report Share Posted February 4, 2010 I have 12.1 inch rotors on stock 510 struts Do your hubs look like this: Those are 4 piston willwood calipers on stock 510 struts... I got everything from Troy Ermish Racing: http://www.ermish-racing.com/510/brakes.html You will need different caliper mounts if you really have 510 spindles on s13 struts Quote Link to comment
thisisthenewsic Posted February 4, 2010 Author Report Share Posted February 4, 2010 I need something that will work that's inexpensive. I will eventually get those wilwood but I just need a cheaper alternative to hold me off til I have more money Quote Link to comment
