cbattey224 Posted January 20, 2010 Report Share Posted January 20, 2010 hey guys i have duel weber carbs that seem to be leaking where they meet the intake manifold. i have nvr had them off the motor before i bought it how it stands. i need whatever gaskets go inbetween?? thanks Link to comment
SSS510 Posted January 20, 2010 Report Share Posted January 20, 2010 Try these guys they carry webber parts... www.racetep.com/weberX.html Link to comment
67411sss Posted January 20, 2010 Report Share Posted January 20, 2010 Doesn't sound like you have softmounts, do the carbs have a plastic spacer in between them and the manifold? or just a thin gasket? i have some softmounts lying around if you need some. Link to comment
hang_510 Posted January 20, 2010 Report Share Posted January 20, 2010 i have some softmounts lying around if you need some. i replaced the o-rings on mine, could be the issue if theyre there. top end http://www.racetep.com/weber.html Link to comment
cbattey224 Posted January 21, 2010 Author Report Share Posted January 21, 2010 its got the plastis spacer and then gaskets? is that normal. it looks as if they made them Link to comment
67411sss Posted January 21, 2010 Report Share Posted January 21, 2010 its got the plastis spacer and then gaskets? is that normal. it looks as if they made them You shouldn't need gaskets if your softmount o rings are in good condition. Any chance you could post a pic or 2.Also you might want to take off the manifold and run a straight edge and see if you have nice straight surfaces on both sides of the manifold. Link to comment
