4DrSportsCar Posted January 9, 2010 Report Share Posted January 9, 2010 This is almost too easy. I see a lot of these with cracked rubber. I took a small sized vacuum hose, slit it open lengthwise, cut it to the size of the eyebtow, a touch of super glue on the inside edge, rub in a little Armor All and you're good to go. Actually gives just a little more emphasis to the grill than the original set up. Hope this is helpful to someone. Quote Link to comment
hang_510 Posted January 11, 2010 Report Share Posted January 11, 2010 This is almost too easy. Hope this is helpful to someone. also the door ding trim that fits on the door works real well, has adhesive. $4 was enough material for 10 or so repairs. a bit less round is all Quote Link to comment
