were do i start?
671rider
  • Replies 4
Pretty vaige question! So vaige answer:
With a 220volt welder, grinder, and sawzall!
There are general rules that apply to all bagging all trucks. I would start with reading this:
http://www.streetsource.com/forum/topic.aspx?topic_id=85853&Page=1
It'll give you some good points about rear suspension design, and if there is anything there that you don't understand, research until you do.
Then there is the front to deal with. Slammy on here recently bagged a 620, as well as beebani. And there are also two build thread from a couple guys from Australia that have bagged theirs, all great resources.
What's your knowledge on air management systems? Air bags, fittings, lines, valves, water traps, air tanks, compressors, relays, switches, gauges, notches, brackets, flow controls, Im sure there are some other peaces that I'm missing to make it all work.
