FoxyRoadster Posted December 18, 2009 Report Share Posted December 18, 2009 I thought about doing a rotary engine which would be badass but well I just don't see it as the best engine to get cost wise for me cause I'm so cheap it proably will make people cry with the corners I'll be cutting. But I'm going to get a 1.8BP out of a Miata... It is a pretty straight forward swap with no frame cutting and makes more sense then this http://datnet.org/General-f33/General-Automotive-Discussion-f3/Datsun-Roadster-miata-t13009.html&hl=fairlady&fromsearch=1 plus the part availability locally compared to the SR20 is much better and this thread kinda killed my want as much for a rotary engine http://forum.miata.net/vb/showthread.php?t=338950 But yeah I think its my best bet and http://www.too-many-parts.com/rs/index.htm just seals the deal. Quote Link to comment
Tomakze Posted March 10, 2010 Report Share Posted March 10, 2010 go KA24! I picked one up for $150 with attached 5 speed and all of the parts including ECU, harness, MAF, and everything! with all the 240sx owners swapping SRs in their cars, KAs are plentiful! no need to cut the frame, stays nissan, i believe it makes more power than the miata engine, and it is seriously torquey!!! anyways, thats my 2 cents... Quote Link to comment
Tacomaboy Posted May 14, 2010 Report Share Posted May 14, 2010 Toma;with reguards to your KA swap, I too am going K24 as well. Your words ring so true. Lbs. for pound, I dont think there is a more senseable engine for the car. The 5 spd.will give all Scratsun can handle. If there were 1 change ,or an area to spend a bit more were would you have put it. I'm in gathering/plan ,mode and just absorbing at this point. Quote Link to comment
FoxyRoadster Posted May 14, 2010 Author Report Share Posted May 14, 2010 Unfortunately every KA I've found out here is 500 dollars or more. I'm also quite the fan of all the aftermarket support the BP has, but for now it will be with the R16 tell I have the cash for the engine. Might get lucky and find a KA. Quote Link to comment
Tacomaboy Posted May 15, 2010 Report Share Posted May 15, 2010 Shoot ; I scored today. 96 DE with 5 spd. MAF,IGN,Auto ECU,full eng. harness. All still mated from 240. Looks like the perfect candidate. 160$ cause I did'nt have change for a twenty. I'll try and get some pic's up tomorrow. Very good picken. Quote Link to comment
