Finally decided on an engine for my project
FoxyRoadster
I thought about doing a rotary engine which would be badass but well I just don't see it as the best engine to get cost wise for me cause I'm so cheap it proably will make people cry with the corners I'll be cutting.
But I'm going to get a 1.8BP out of a Miata... It is a pretty straight forward swap with no frame cutting and makes more sense then this http://datnet.org/General-f33/General-Automotive-Discussion-f3/Datsun-Roadster-miata-t13009.html&hl=fairlady&fromsearch=1
plus the part availability locally compared to the SR20 is much better and this thread kinda killed my want as much for a rotary engine http://forum.miata.net/vb/showthread.php?t=338950
But yeah I think its my best bet and http://www.too-many-parts.com/rs/index.htm just seals the deal.
  • 2 months later...
  • Replies 4
go KA24! I picked one up for $150 with attached 5 speed and all of the parts including ECU, harness, MAF, and everything! with all the 240sx owners swapping SRs in their cars, KAs are plentiful! no need to cut the frame, stays nissan, i believe it makes more power than the miata engine, and it is seriously torquey!!!
anyways, thats my 2 cents...
  • 2 months later...
Toma;with reguards to your KA swap, I too am going K24 as well. Your words ring so true. Lbs. for pound, I dont think there is a more senseable engine for the car. The 5 spd.will give all Scratsun can handle. If there were 1 change ,or an area to spend a bit more were would you have put it. I'm in gathering/plan ,mode and just absorbing at this point.
