newguy Posted December 9, 2009 Report Share Posted December 9, 2009 I have air ride on my 620 and one of my valves keeps sticking or freezing up. There 1/2 fast acting brass valves and the only way I can get it to work is to take a propane torch it. warm it up and it starts working. does anyone with air ride have this trouble in winter? Does anyone know of a 12 volt heat tape or blanket? Quote Link to comment
DISLEXICDIME Posted December 9, 2009 Report Share Posted December 9, 2009 I have air ride on my 620 and one of my valves keeps sticking or freezing up. There 1/2 fast acting brass valves and the only way I can get it to work is to take a propane torch it. warm it up and it starts working. does anyone with air ride have this trouble in winter? Does anyone know of a 12 volt heat tape or blanket? I wonder if you can use the anti freeze they put in the air lines for diesel's Quote Link to comment
oldsklminitrk Posted December 9, 2009 Report Share Posted December 9, 2009 I wonder if you can use the anti freeze they put in the air lines for diesel's Yeah thats one of the best things to use....also you need to get a water trap on that setup if your valves are sticking....cause that means the water in the lines is freezing.But air brake antifreeze works good. Quote Link to comment
newguy Posted December 10, 2009 Author Report Share Posted December 10, 2009 sweet I'll try the air line additive. and get a water trap. Quote Link to comment
Tdatsun1971 Posted December 10, 2009 Report Share Posted December 10, 2009 They do make a heat tape, but i have only seen it for 120v. That would be a great idea!!!! Also a water trap will help in the winter. Not to sure on the anti-freeze additive I will try and ask some others about this. I dont know anyone around my area that uses that. Just my 2 cents worth. Quote Link to comment
cbattey224 Posted December 14, 2009 Report Share Posted December 14, 2009 sometimes when i go snow boarding i just get hot water and pour it in the valves and it works. lol i was stuck for a while the first time till i got the hot water idea. Quote Link to comment
Smiley720 Posted December 15, 2009 Report Share Posted December 15, 2009 You can also place the valves closer to the bags and get them away from the air tank. My front valves were right on the front fenders and I never had them freeze up on me, even in the Colorado winter Quote Link to comment
