integradude19 Posted December 4, 2009 Report Share Posted December 4, 2009 Can you remove it without taking the carb assembly off the intake manifold? 1979 620-Stock L20B Quote Link to comment
datzenmike Posted December 4, 2009 Report Share Posted December 4, 2009 (edited) Yes. It's the round thing to the right with a cone shaped bottom. Usually three Philips screws holding the top on. There is a spring and a diaphragm underneath that so don't let it pop out. http://i138.photobucket.com/albums/q251/datzenmike/carbLseriesBCDD.jpg[/img]"] Edited December 4, 2009 by datzenmike Quote Link to comment
integradude19 Posted December 4, 2009 Author Report Share Posted December 4, 2009 One of the screws is covered by the choke accuator. Any trick to getting under that? Maybe flat head screwdriver turned side ways? Quote Link to comment
datzenmike Posted December 5, 2009 Report Share Posted December 5, 2009 If it's the small round thing with a hose on it, that's the vacuum break assy. If you can't get around it, leave it and disconnect the linkage to the secondary below the diaphragm, them unscrew the diaphragm and remove it to work on it. Quote Link to comment
