thinking of buying 1990 kc 4x4 today
feefifofum
  • Replies 1
rust, leaks, funny noises from drive train. anything out of the ordinary, check under it as well for anything bent, broke, worn etc.
Whenever buying a car you need to do a THOROUGH check over on it. Everything, every little detail. Worn seals on the doors, sloppy clutch, broken glass, busted tail lights, dents etc. check for a nasty wiring harness, blah blah etc etc :D
Take your time and give it a rough inspection. If they don't like you taking the time to look over it then move on... shake the tires and see if the bearings are worn out too.
