sr20de non turbo wiring help please
bazchch
got an sr20de and loom and ecu from a u13 nissan
looking for pinout to get this running,of the factory ecu.
the knock sensor wires is not apart of the main engine loom
any one know how to add these in to the engine loom[pins]
car is going to be a track car , so i only need power and earth to the ecu pinout to a power switch,
' or do i need relays etc
fans will be on a switch and fuel pump power straight from the main switch
any help would be great
would like to get engine wired and running before the roll cage goes in''
thanks baz:D
  • Replies 2
mine has 3 plugs coming from the main ecu plug.
it was from a 1994 u13 bluebird sr20de non turbo
1st is 8 pin plug [white]
white wire
orange
white,green stripe
pink,black stripe
big black with red stripe
white
small grey
2nd plug
black flat style plug
black
orange with blue stripe
green
purple
green with black stripe
WHITE FLAT STYLE PLUG
WHITE
GREEN,BLACK stripe
yellow,black stripe
green,white
yellow,red
black yellow
grey,red stripe
green,brown
yellow
lightgreen,red
yellow,blue
blue,black
yellow,green
i have some pics of the loom and wires
but not sure how to add them to here
