Nissan Z2.4
imtb
I was just checking to see if anyone knows much about these engine. If would be a good swap in 510. The engine is carb'ed not fuel injected.
I think you have to use the L16 oil pan, what about the tranny would a zx or dogleg work, what about the tranny that came with the z2.4 in the hardboyd PU.
I tried a search but didnt find to much, if you have any info pass it along.
thanks
  • Replies 1
Use the Z tranny. The one from the Hardbody will work but the 510 driveshaft will need shortening as it, the tranny, is much longer.
The Z24 (truck) oil pan won't work. A pan from a Z20 or Z22 car (200sx, A10) oil pan should work, NOT the 510 oil pan.
