620 window channel felt replacement
650savag
I just got my truck back from the paint shop (78 KC) and the stuff that I had been using for window felt was missing from one window and the other window was loose and slipping out. I had replaced the door weather stripping on both doors awhile back and I was using some of the old door weather stripping, cut to length, for window felt. The rubber weather stripping fit in the metal clips pretty good but I don't have anymore of that. What are some good ideas for replacing the window felt without removing the door panels and buying the expensive window felt?
  • Replies 4
