what Posted August 10, 2009 Report Share Posted August 10, 2009 Wondering the fuel tank capacity for trucks. Will they interchange. For instance if the 620/720 fuel tank holds more gallons will it fit properly in the 520/521? Quote Link to comment
datsunaholic Posted August 10, 2009 Report Share Posted August 10, 2009 Of bigger concern is that the filler neck is on the wrong side. 520/521 are on the Driver's side (left) whereas 620/720 ones are on the passenger (right). Plus they mount in different fashoins. Quote Link to comment
Loz Posted August 10, 2009 Report Share Posted August 10, 2009 any advice on removing the fuel tank cos mine is blocked and I'm running around with a 5 litre oil can of fuel in the back for now. not big not clever and not that safe I guess... Any help getting the rusted fixings off, apprecieted. any tips on cheap easy un blocking of tank also welcome. Quote Link to comment
Braden Posted August 10, 2009 Report Share Posted August 10, 2009 use an impact to get the rusted bolts out, if they break that is ok because you should replace them with new hardware anyways, if that doeasnt work you could always cut them with a sawzaw and a metal blade!!! any advice on removing the fuel tank cos mine is blocked and I'm running around with a 5 litre oil can of fuel in the back for now. not big not clever and not that safe I guess... Any help getting the rusted fixings off, apprecieted. any tips on cheap easy un blocking of tank also welcome. Quote Link to comment
Braden Posted August 10, 2009 Report Share Posted August 10, 2009 Just wondering what is the fuel capacity of a 620 fuel tank? I just installed mine and i was wanting to try and check my gas mileage. Thanks Quote Link to comment
