astro_ss_340 Posted August 9, 2009 Report Share Posted August 9, 2009 Ok, I am not tall but I am extremely husky, and the steering wheel hits me in the chest, how can a guy move the steering column so there is more clearance, I would like to shorten it by 6 to 8 inches. And from what I can see I think I will have to pull the steering wheel off, cut 8 inches out of the housing and shaft and then weld the spline for the steering wheel back on. Am I correct? or is there an easier way, (IE) some other Datsun I can swap the whole assembly out? Thanx in advance Morgan Quote Link to comment
dat u racing Posted August 9, 2009 Report Share Posted August 9, 2009 you can cut the column check my thread ka24-521 there is a few pic's. installed a chev tilt with splined unaversl to fit chev side and 3/4 round weld on for the box side, the center mount carrier bearing support bracket is just about a bolt in column support under dash. Igot the universal from speedway moters.com.This would be a good time to upgrade with new fuse box and all the controls on chev column would plug into new fuse box Quote Link to comment
Bugeye Posted August 9, 2009 Report Share Posted August 9, 2009 you can cut the column check my thread ka24-521 there is a few pic's. installed a chev tilt with splined unaversl to fit chev side and 3/4 round weld on for the box side, the center mount carrier bearing support bracket is just about a bolt in column support under dash. Igot the universal from speedway moters.com.This would be a good time to upgrade with new fuse box and all the controls on chev column would plug into new fuse box +1 Since I have the EZ wire wiring harness I am going to be using a tilt column from a camaro best thing I think I can do for the interior of my truck Quote Link to comment
Guest DatsuNoob Posted August 10, 2009 Report Share Posted August 10, 2009 Let us know how that works out. I would love more space, I just got a slightly smaller steering wheel, but I'd love a few more inches of breathing room. Do you know how much shorter a camaro column is vs a 521 or 620? Quote Link to comment
Bugeye Posted August 10, 2009 Report Share Posted August 10, 2009 havent measured it yet, still need to get the camaro column, Quote Link to comment
DRIVEN Posted August 11, 2009 Report Share Posted August 11, 2009 Not a Camaro, but...I pulled a tilt column from a '85 Cavalier with floor shift. Bottom end of spline to top of column (at the face that mates to the steering wheel) is 23". Since it is a FWD the column is pretty stubby. This can be helpful getting around obstacles like frame or exhaust. Added bonus is that it should be direct plug-in for aftermarket harnesses. Thought I'd add this as an option. Quote Link to comment
