sdsurf Posted July 13, 2009 Report Share Posted July 13, 2009 My fuel pump is working fine out of a gas can but when I try to go from my tank, I get nothing. There are 5 gallons in there so I know that isn't the case. Where should I start? Quote Link to comment
Bugeye Posted July 13, 2009 Report Share Posted July 13, 2009 sounds as if the line is plugged inbetween the tank and the pump, I would disconnect the line at the tank and pump and use compressed air at the tank side and blow out the line. the sending unit in the tank might also be plugged Quote Link to comment
dgi Posted July 13, 2009 Report Share Posted July 13, 2009 Verify your fuel filter (near the fuel pump) is not clogged with debris/rust. The pickup tube in the tank on PL521s is bad about rusting through and getting pin holes. If one of those pin holes is above the level of the gas, the fuel pump will only pull air. Don't ask me how i know :mad: Quote Link to comment
sdsurf Posted July 13, 2009 Author Report Share Posted July 13, 2009 Verify your fuel filter (near the fuel pump) is not clogged with debris/rust. The pickup tube in the tank on PL521s is bad about rusting through and getting pin holes. If one of those pin holes is above the level of the gas, the fuel pump will only pull air. Don't ask me how i know :mad: Installed new fuel pump and got nada. But I will try blowing out the lines and see what happens. if not plan B. The pickup tube is accessible from the access door in the bed, right? Quote Link to comment
Pacific coast Datsun Posted July 14, 2009 Report Share Posted July 14, 2009 Mike, are there any ports on the tank not being used? If so they need to be plugged. I plugged 2 on mine using small pieces of fuel line & a 10mm bolt jammed into the end. Just a thought. Quote Link to comment
dgi Posted July 14, 2009 Report Share Posted July 14, 2009 The pickup tube is accessible from the access door in the bed, right? Yep. Quote Link to comment
sdsurf Posted July 16, 2009 Author Report Share Posted July 16, 2009 blew it out and it works great!! Quote Link to comment
