dat521gatherer Posted June 26, 2009 Report Share Posted June 26, 2009 so my 521 hasn't been starting to well in the morning. i opened the throttle and saw a puddle of gas in the bottom of my intake manifold. i know the carb could use a rebuild but is there a specific problem i should be looking for to address this? thanks Quote Link to comment
datzenmike Posted June 27, 2009 Report Share Posted June 27, 2009 Webers, specially old ones are very sensitive to flooding if fuel pressure is above 3 PSI. Float level may be set to high. Backfiring can sometimes throw it off. Change your fuel filter. Cut the old one open and see if it's come apart or has dirt in it. Any dirt that gets past it will and can stick in the inlet needle valve which is opened and closed by the float. If it can't close the bowl will over fill with fuel and flood. Quote Link to comment
dat521gatherer Posted June 27, 2009 Author Report Share Posted June 27, 2009 awesome, thanks mike! Quote Link to comment
