dat u racing Posted March 30, 2009 Report Share Posted March 30, 2009 Distributor help!! IM WORKING ON MY KA, converting the Distributor base from an lb20 to a ka. On the Lb20 riser only one hole lands on the ka. case an its suspose to have 2 will it hold with only one bolt Quote Link to comment
datzenmike Posted March 30, 2009 Report Share Posted March 30, 2009 (edited) You've swapped a Z24 spindle in it already right??? The KA spindle is splined to fit the KA CAS. You can see it in this picture: Hmmm that's interesting. Well, take a look at a Z24 timing cover. It has the bolt holes that will fit the dizzy base.... not sure the L dizzy will work on it or not though. Here's a Z24 timing cover with dizzy. http://i138.photobucket.com/albums/q251/datzenmike/720%20stuff/720stuff056Large.jpg[/img]"] Here's a Z22 timing cover ... same as a Z24 only 2cm shorter. That's a Z24i CAS that fits in the end. http://i138.photobucket.com/albums/q251/datzenmike/720%20stuff/720stuff058Large.jpg[/img]"] Best fit would be a Z24 timing cover with 4 plug Z20E EI dizzy Edited March 30, 2009 by datzenmike Quote Link to comment
dat u racing Posted March 30, 2009 Author Report Share Posted March 30, 2009 I no the shaft has to be changed to a (z) shaft but what i was woundering is how to mount the base plate to ka. case. an if one bolt will hold the dizzy instead of two. (from ka case to l20b base) Quote Link to comment
