Mydime Posted March 17, 2009 Report Share Posted March 17, 2009 Hey guys, I could use a little help if anyone can. I have collected a bunch of parts an am now ready to move forward a little at a time. Most recently just finished the CA18ET rebuild which will be going in. I would like to take care of any modifications that may be needed while there is no motor in it. My question is can I ditch the torsion bars up front in favor of coilovers? If so, has anyone here done this? What spring rate, and shock length would I be looking at? Any help is greatly appreciated. Thanks, Glen Quote Link to comment
Mydime Posted March 21, 2009 Author Report Share Posted March 21, 2009 So I was reading the forum and about the only thing I could find was Finelines truck, which I could only get the spring part number off of the pic. That is a 300 lbs spring part# from QA1 Toxic shocks lists their front shocks for a "lowered" truck as being: Extended: 13.35" Collapesed: 9.01" Any input on this info would be great. I guess logic of deduction would lead me to beleive that the above specs are what I should follow in purchasing a set of coil overs for my 72 620. Quote Link to comment
datzenmike Posted March 21, 2009 Report Share Posted March 21, 2009 I believe Pinto shocks are shorter than stock 620. Quote Link to comment
Mydime Posted March 22, 2009 Author Report Share Posted March 22, 2009 (edited) So I re read the description on the toxic shocks and those previous specs are for a 2" lowering job. Mine is lowered at least 4". So I beleive that I will need something shorter than what they list. Would I look for something that is 2" less than the specs that Toxic Shocks posts? QA1 http://qa1.thomasnet.com/viewitems/sports-street-rods-shock-absorbers-shock-absorbers/ultra-ride-174-adjustable-coil-over-shocks?&plpver=1001&forward=1 Part# UR3855B Bearing Compressed:8 5/8 Inch Extended: 11 1/8 Inch Recomended Ride Height: 9 3/4 in. - 10 1/4 in. $189.95 These are kinda what I was looking at getting, anyone have any opinions on these? Thanks, Glen Edited March 22, 2009 by Mydime Quote Link to comment
