izzo Posted March 8, 2009 Report Share Posted March 8, 2009 (edited) Whomever has a weber in a 620/720 please post a pic of how your throttle cable is attached to the weber itself I got mine half installed today, but want some ideas for tomorrow when i hook it up the rest of the way I got the weber on, or so i thought. kicked it over a few times and it was backfiring out the carb. Turns out i didnt have it bolted down all the way and i cant freakin get in there to get that damn nut tight. ill have to work at it tomorrow. thanks to Datto510 for helping me out troubleshoot what the problem was. Edited March 8, 2009 by h2theizzo Quote Link to comment
spottedog Posted March 9, 2009 Report Share Posted March 9, 2009 (of the correct size for your carb base nuts), put the box end in a vise and heat it cherry red with a propane torch just a bit up from the box end. Using vice grips, bend the remainder of the wrench to about a 45 degree angle. After it cools (or drop it in your dogs water bowl) try it on the hard to reach nuts, reheat and increase/decrease angle as needed. Quote Link to comment
