BRAAP Posted March 4, 2009 Report Share Posted March 4, 2009 For sale, complete front and rear suspension set up for an S-30. Pulled from my yellow track car, ALL consumables were replaced with new, approx 6 hours time on all parts! Strut tubes were sectioned for lower ride height and no loss of suspension travel, coil overs installed for fully adjustable ride height. Tokico 5 way adjustable strut inserts front and rear purchased from Ground Control for the shorter strut tubes. Ground Control coil over front and rear. 2 springs 250 in/lb, other 2 springs 275 in/lbs. comes with 240-Z rack, (quicker ration than 280 rack), front and rear control arms, front and rear cross-members, T/C rods, sway bars, etc. New parts; Front; Inner and outer wheel bearings. Lower ball joints. Outer tie rod ends. Poly control arm bushings, Poly T/C rod bushings, Poly rack bushings. Bump steer spacers. Brake rotors, Tokico Illuimina 5 way adj strut inserts. Suspension Tech 1" front bar with poly bushing and end links. Rear; Wheel bearings. Inner and outer poly control arm bushings. Rear brake rotors. Suspension Tech. rear mount rear bar with new uprights. Tokico Ilumina 5 way adjustable struts. You will need to get upper spring perches, can be had direct from Ground Control, last I checked they were $17 a-piece, need 4. You will also need your own front calipers and rear calipers with brackets. $1000 obo for everything! Pick-up in Sandy OR or I'll deliver within 100 mile radius of the greater Portland OR area free. Contact me via PM here or E-mail; braapZ350@hotmail.com If to be shipped, add $150 for professional crating from gateway crating service, plus freight fees. I have an account through Yellow/ROADWAY inc, will save on freight costs. Shipping will be to your nearest Yellow Roadway shipping dock. Front susp ; Rear susp; 5way adj strut ; Example of crating if being shipped ; Link to comment
Phlebmaster Posted March 4, 2009 Report Share Posted March 4, 2009 Dang! Makes me wish I had a Zcar. :D Link to comment
280zx2by2 Posted March 4, 2009 Report Share Posted March 4, 2009 Dang! Makes me wish I had a money. :D Link to comment
