Lol. Yup, the rear coilovers were turn all the way up... You are right Btw.. I try to make it so It's the perfect height for daily town driving. :) I like it nice and fitted! Lol,
yeah I did all the measuring. 16s would def. hit...
even with the 15s.... clearance allowance behind is not really forgiving either. So I'm hoping 5 mm spacer will do the trick. I know it's going to be super tight, but I'm hoping the end result will be a perfect stance...:)
yeah the coilover appears to be raised all the way up. But it still bounces. As expected I guess. But I know I ran 15x9 +20 offset before and it doesn't rub at all. So I'm hoping with the -0 offset on these wheels I will still be ok. lol. I'm stretching the crap out of the tires tho.
The wheels are Shakotan. All 4 of them are 15x9 with a -10 offset.
The car is a 72' 4 door Dime that has fender flared out. I have rear coilovers on the car and I believe 280 front with disc brakes. The coilover seems to bounce a lot. I'm thinking about just going with blue tokicos shocks to eliminate the bounce.
I was thinking using 195/45/15s stretched tires. I've tested fitted the wheels/ mount them and rolled it by hand with clearance. (fronts and rears) See photos. What is your guys opinion and will it definitely fit or not? I also ordered some 5mm spacer just in case...\
-again I wasn't the one that built this car. Was told they were just some JDM Fender Flares added onto the car
-It is not currently registered with the BLACK and Yellow plates because I just ordered them and received them not too long ago.,Plus at this time I don't have time to go back to the DMV to do all the specialized/ historical plate registered. But the plates are cleared that I confirmed. I might very well go sometime this week to registered the plates...:)
