As in what seeps into the fuel door? Or the evap can in the bed wheel well? The original sender o ring was shot and figured the water came from washing the mud off the chassis.
We have actually got some rain and between that and a trip to the dump and trying to get the truck clean we got water in the tank. Found an O ring for a Z so hopefully that fixes that. Finally got the valve cover back from powder coat.
I agree. This was a compromise. Truck is low so most people will see it. Other low cars will not. If I were to run it in the cab the option earlier in this post would be better.
It is loud especially compared to modern cars. Compared to some of mine it is pretty quite. The insulated cab makes it fine, can talk while driving. It does set of my neighbors car alarm though. Is anyone going to eagle rock?
No plans for paint. He wants patina and I don’t want to be mad if he scratches it. That’s why I bought a green parts truck so we wouldn’t need to paint. The daylight pic is above, I will get a night shot later. It has a low/running brightness and a high/brake brightness.
Finally got the mirror arm from Japan. Added a universal mirror, a tip I found on ratsun. 15” fentons came in and got those polished. Had some Toyo’s mounted today. Installed the third brake light on the box. Gets an alignment next week. Just waiting on the valve cover from the powder coater.
Finally got around to trying to fix the fuel tank pickup. Decided to use the original location. Little sketchy but broke off the nipple on the tank. Drilled the tube flush and removed it. Amazed it got any fuel at all. Almost completely clogged and assume there are pin holes also. Made a new one out of 4AN stainless and a bulkhead fitting. Tried to bubble flare the top nibble but the stainless was too think. Pain to get in and tight but new tanks aren’t an option.
Also found a staggered set on 15x8.5/15x6.5 Fenton slotted mags. Should have then next week. Still waiting on fuel sender that hopefully works and a mirror from a buddy in Japan.
My son is definitely gets the final say on his truck. I have a tendency to take things over so I have been really putting forth effort to make sure he has control. I found a set of staggered fentons.
He likes old school. He’s more conservative than I am. I got him a header, he wanted the roadster manifold. I got him dual side drafts, he opted for the 32/36 on an old offenhauser manifold. I say big steelies, he says 14” mags. Rolls are kind of reversed.
You are right. I’m not exactly a people person. I can fix cars, not people. Plus I wanted his first car not to suck. Mine did. Opel GT that was won on the price is right in 1972. Never ran right, improperly installed cam bearings. Sold it to a guy in the Netherlands and joined the Navy.
