I'm building a 1974 620 pickup with a s13 sr20det I've also done a conversion for a Watts link 5 point rear suspension setup with adjustable coilovers front and rear. For spindles I'm running 95 d21 fronts that I've swapped sides to make it front steer does anyone have any suggestions for a power steering rack?
I've got a L18 motor and trans from a 1974 620 if anyone needs it it was rebuilt and ran for break in about 20 years ago and sat ever since I did make it run but would would personally g through all the gaskets and seals
I am in the middle of a Sr swap and have added some extra power parts as well as a 5 link coil over conversion kit so the rear gear is definitely going to need to be taller thank you for your help and Input
