I've been reading the write-ups on swapping 2wd hardbody disc brakes/spindles/hubs onto my '73 620. I made custom upper control arms to make it work, got the whole hardbody spindle, lower control arm, etc. from a 4 cyl D21.
I used the hubs from the '73, with the hardbody bearings to fit onto the hardbody spindles.
I decided to upgrade to the 2 piston pathfinder calipers/brakets while I was at it. I got these from a '97 Pathfinder
So, from what I understand - from what I've read; you use the Honda Passport rotors with this setup.
I got the Passport rotors, and went to put the pathfinder caliper/bracket on, and they will not fit without rubbing the rotor. Did I misunderstand or miss something? Please help!
