Montzzz Posted April 29 Report Share Posted April 29 I notice that my brake lights were staying on all the time. The problem was at the brake pedal switch, it became loose so i unplugged one terminal and tight the switch. when i connec†ed back the terminal I accidentally touch the other terminal and I could see a tiny spark. After that my truck wouldnt start. Since is stickshift, i pushed it and started on second gear. Drove it for 20 minutes, ran fine then turned it back off and turn it back on and nothing, no juice whatsoever so ipushed it againg and started like that. While driving home i turn on the lights and the truck lost power, turned lights off and gain power. Got home and while the truck was on i took the negative terminal off the battery and truck died. So my question is what did I burned? I check the fuses and they are all good. thanx in advance Quote Link to comment
