Reinere Posted March 4 Report Share Posted March 4 Just reposting this off zilvia. Figured it would be helpful to anyone needing it. Engine (E.F.I.) Harness F1 – To main harness (M53) F2 – E.C.C.S. control unit F3 – To engine room harness (E114) F4 – To engine room harness (E115) F5 – To engine room harness (E116) F8 – To engine room harness (E9) F9 – To engine room harness (E10) F10 – F.I.C.D. solenoid valve F11 – A.A.C. valve F12 – Injector no. 4 F13 – Air regulator F14 – Injector no. 3 F15 – Pressure regulator control solenoid valve F16 – S.C.V. control solenoid valve F17 – Exhaust gas sensor F18 – Injector no. 2 F19 – Injector no. 1 F20 – Engine ground F21 – Crank angle sensor F22 – Engine temperature sensor F23 – Thermal transmitter F24 – Throttle valve switch F25 – Throttle sensor F26 – E.G.R. control solenoid valve F27 – Air flow meter F28 – Tacho resistor F29 – Condenser F30 – Ignition coil F31 – Power transistor F32 – Front wheel sensor R.H. Lower Engine Harness (A/T) E201 – To engine room harness (E11) E202 – To engine room harness (E17) E203 – To engine room harness (E18) E204 – To engine room harness (E19) E205 – Battery E206 – Power steering oil pressure switch E207 Alternator E208 – Oil pressure switch E209 – Starter motor E210 – Exhaust gas temperature sensor E211 – Vehicle speed sensor E212 – Back-up lamp switch E213 – Neutral switch E214 – 5th position switch I'll try to find pinouts and add them to this thread if I can. 2 Quote Link to comment
