JumboFett Posted May 23, 2023 Report Share Posted May 23, 2023 Hi team! Years ago somebody asked these questions, but I didn’t see an answer: Will my 78 hub fit on the Hard Body spindles? And if I want oversize brake setup, can I get the rotors off a V6 Hb 2x4 and the calipers off a 4x4 HB? Is that a viable combination? Thank you! 🙏 Quote Link to comment
Wildcat Walker Posted May 23, 2023 Report Share Posted May 23, 2023 (edited) What you want is a Z32 caliper and rotor adapter. This is a kingpin truck that has been converted to D21 spindle and ball joints. Edited May 23, 2023 by Wildcat Walker 1 Quote Link to comment
JumboFett Posted May 23, 2023 Author Report Share Posted May 23, 2023 Although that is awesome that might be too much brake for my little truck and littler wallet. Really just interested in getting the answers to the above questions. Thank you Quote Link to comment
JumboFett Posted May 23, 2023 Author Report Share Posted May 23, 2023 Hey y’all, just bumping this thread in the hope of generating more traffic. Thank you Quote Link to comment
JumboFett Posted May 23, 2023 Author Report Share Posted May 23, 2023 10 hours ago, Wildcat Walker said: What you want is a Z32 caliper and rotor adapter. This is a kingpin truck that has been converted to D21 spindle and ball joints. You know what, maybe you’re right. Maybe I’m prejudging the cost and/or retrofit. Do you happen to have a parts list to put a z32 swap in my ball joint spindle setup? Thank you 🙏 Quote Link to comment
Wildcat Walker Posted May 24, 2023 Report Share Posted May 24, 2023 I literally paid $10 for each z32 caliper with like new Nissan pads and hardware. The spindles are cheap or free. Shop around. 1 Quote Link to comment
victhewhimpykid Posted June 2, 2023 Report Share Posted June 2, 2023 On 5/23/2023 at 4:48 AM, Wildcat Walker said: What you want is a Z32 caliper and rotor adapter. This is a kingpin truck that has been converted to D21 spindle and ball joints. Do have pics of what you did with the tension rods up front where they meet the frame?? Im currently converting from king pin to ball joint. Quote Link to comment
Wildcat Walker Posted June 3, 2023 Report Share Posted June 3, 2023 On 6/1/2023 at 7:49 PM, victhewhimpykid said: Do have pics of what you did with the tension rods up front where they meet the frame?? Im currently converting from king pin to ball joint. No, I used the same exact parts that Mike Klotz used on his custom LCAs. The stock 620 tension rods mounted to modified d21 lower arms. Nothing fancy or special. Quote Link to comment
