Joker_andthe_thief Posted May 29, 2022 Report Share Posted May 29, 2022 Well I was able to mount 240zx Coilovers onto my 280zx after a few years of mucking about. Mount Coilovers (front are direct fit rear req redrill) Install 240sx front knuckles, Install 240sx eBay ajustable lower control arms, (chyna, Megan, cusco) **** you will need to sand down or grind off 1-2mm from the LCA heim joint to slide it into the Datsun subframe **** you will need to order m14x1.5mm threaded rod to extend your tie rods and adjust for misalignment, For the castor/traction bar, you will need a custom adapter! (Pic inc.) 1 Quote Link to comment
