WestPac720 Posted February 7, 2022 Report Share Posted February 7, 2022 (edited) Need help! Anyone have this kind of setup on their 720? This is the thermo switch that goes into the AC evaporator box. I found this photo on another post created by MadKaw but thought I bring it back to life to see if anybody else has the same setup or any additional info regarding models with AC and non AC for our 720s. This setup does not have any AC relay rather the plug where the AC relay would connect to, is connected to the thermo switch. Im in the process of hooking up all my AC electrical components but can’t seem to get a good 12v to the only line to the compressor. Any help would be greatly appreciated. Those who commented previously, thank you as well. Edited February 7, 2022 by WestPac720 Quote Link to comment
WestPac720 Posted February 7, 2022 Author Report Share Posted February 7, 2022 This is how the connection looks after I pulled out the thermistor from inside the evaporator box. The white fusible link is where the wires for the low and high pressure switch connected to. The ground wire was grounded on the evaporator box bracket located in the front. Quote Link to comment
