sicripp83 Posted August 23, 2014 Report Share Posted August 23, 2014 hey everyone New to the forum, my name is josh and I just bought my first z. the car was zebarred from the factory so the underbody, floors, spare tire area are sweet. typical rust on fenders and dog legs. But the problem im having is that while it will idle fine, and rev while in neutral, but when go to drive it, it will spit and spudder (lack of better words) I don't have a lot of time driving it, because im waiting for a wheel cylinder. should be here Monday. I should let you know that this car was in storage for 7 years before I got the car. so far I have drained the old gas (it was bad) filled with fresh gas and sea foam. fuel filter has been changed twice. the plugs and wires were changed along with the cap and rotor, air filter and oil were also changed. I also removed the MAF and checked the flap door. it opened and closed. im at a loss. any suggestions would be great thanks guys Quote Link to comment
eddieeats Posted August 23, 2014 Report Share Posted August 23, 2014 Draining and refiliing the gas tank is not enough. First change out hte fuel filter and tuen the car, also put a Fram 3G filter between the taks and the pump, it's clear so you can see how much varnish is coming out of the tank. Then you may need to drop the tank and clean it out, either power wash it and let it dry or pay to have it done. Your problem is most likely fuel dilivery! Quote Link to comment
