joshotto94 Posted June 12, 2014 Report Share Posted June 12, 2014 i have a 280 im getting spark and the car will start off starting fluid. the car seems to no be getting fuel like the injectors are not opening any suggestions would be geat thanks you JOSH Quote Link to comment
ggzilla Posted June 12, 2014 Report Share Posted June 12, 2014 How have you verified that no fuel is coming out the injectors? Is the fuel pump working? How many psi do you measure? Quote Link to comment
joshotto94 Posted June 12, 2014 Author Report Share Posted June 12, 2014 i pulled the fuel line off as close to the injectors as i could get put the line in a bucket and cycled the key plenty of fuel poured into my bucket Quote Link to comment
ggzilla Posted June 12, 2014 Report Share Posted June 12, 2014 So problem solved? Or is it still having some problems? Quote Link to comment
joshotto94 Posted June 12, 2014 Author Report Share Posted June 12, 2014 no that is how i determined there is fuel to the line the injectors are no shooting fuel for some reason any suggetsions Quote Link to comment
ggzilla Posted June 12, 2014 Report Share Posted June 12, 2014 "plenty of fuel" can pour into a bucket and still not be enough pressure foe the injectors. I would test the actual pressure and the volume. A $35 gauge will do it. Other ideas are a blown fuse, faulty relay, stuck air Meter. Quote Link to comment
joshotto94 Posted June 12, 2014 Author Report Share Posted June 12, 2014 I had a multi meter on the injectors and I was not getting a pulse signal at all Quote Link to comment
