boonedock saints Posted February 19, 2014 Report Share Posted February 19, 2014 Alrighty, quick question....we are about remove the motor to clean the bay and wiring up a bit. The motor checks out in all aspects, and the twins funds are comming to the end. This means we are not going to remove the head, timing chain, compression and oil leaks all seem to be solid. The valve cover is getting polished, and thought was to clean up the valve train intact. Ive done this on beater cars that were being sold or drivers...but this is a bit different..... Has anyone had good results...meaning decently cleaned, no leaks from seals afterwords..? Much appreciated. If it were mine Id just rebuild it, but these guys are chomping at the bit to drive. Quote Link to comment
