Josh K. Posted April 13, 2014 Report Share Posted April 13, 2014 Word of advice. Push that ka back to the firewall or you'll end up like me trying to fit a fan... Josh- 1 Quote Link to comment
dime'n daily Posted April 14, 2014 Author Report Share Posted April 14, 2014 any tips/tricks to doing so? appreciate any help or advice. once I get the motor back together im going to test fit it with tranny, wire it up, and get it running. then pull it back out to get the brake lines done and possibly paint. and then still have to do all chassis wiring Quote Link to comment
Josh K. Posted April 15, 2014 Report Share Posted April 15, 2014 My car already had the motor installed so I can't help. I can only tell you how difficult it is with the motor forward. From what I've seen pushing it back still makes for a tight fit for fans/rad. If my turbo manifold, exhaust, drive shaft and tranny tunnel weren't done I would move mine back. Unfortunately all those things would need to be modified now... Josh- Quote Link to comment
dime'n daily Posted June 11, 2014 Author Report Share Posted June 11, 2014 so i never update seeing im always busy. lately just been enjoying the 4 dr and recently pulled the motor to clean up the engine bay and do some gaskets. also started trying to clean up the body a bit. still a work in progress but heres some pics and i needed a crank and rod for the dual cam for my 2dr. came across a deal on a blown headgasket complete block for $20 more than i wouldve paid for the crank and rod. got it torn down and you can see motor has been rebuilt somewhat recently. head was really clean, timing chain guide broke like usual. just waiting on a headgasket and chain kit so i can put it back together. got the head resurfaced plan is to get this motor in within the next week or so and order a wiring specialties harness so i can hopefully have the 2dr running soon. one of the service advisors at my dealer used to build 510s, he gave me a set of 90mm pistons he had brand new. and the shop foreman/master tech used to work for datsun back in the day and after that nissan for many years and they love to help out. with the other block im going to bore it out to use the 90mm pistons, and get some brian crower stage 2 cams, so once i have the 2dr running just switch over the block, and put in the cams still a long way to go, but a light is starting to appear at the end of the tunnel. oh and i might be adding another 4dr to the pack, well see how things go by the end of the week, as if two werent enough. Quote Link to comment
dime'n daily Posted June 11, 2014 Author Report Share Posted June 11, 2014 anyone need a single cam haha? Quote Link to comment
dime'n daily Posted June 22, 2014 Author Report Share Posted June 22, 2014 so i finally got an ecm and wire harness and got it all wired up to the can am. tomorrow ill probably test fit it with the tranny bolted up, just need to get a trans mount, and see how much banging of tranny tunnel is needed. i see a light at the end of the tunnel, still so much to do though, hopefully she will at least run within the next few weeks thought id leave this here, hopefully in the future mine will have one. seeing i work at honda, it only seems right hahaha :) when i picked up my harness at a shop by my house, they were building it for a customer Quote Link to comment
dime'n daily Posted July 2, 2014 Author Report Share Posted July 2, 2014 so finally got the motor and tranny all mounted and it sitting as far back as it can. productive day off. now I just need to measure for the driveshaft...once I get one made ill be a happy camper. can anyone show me to some flexible brake lines. a shop quoted me $500 to do mine,but I have better things to spend that money on. and I don't want to bend them myself because I want it to look good. Quote Link to comment
dime'n daily Posted July 13, 2014 Author Report Share Posted July 13, 2014 where im at as of now... getting my driveshaft cut hopefully done on monday. everything else mounted. still need a radiator and headers...anyone got input on headers? i hear most people use obx? got a pedal out of a 240 happy with how it sits might need to make like a 2in spacer between the mount and pedal to bring it up a tad, and single cam throttle cable which is close to perfect. currently working on completing my stock dash...hopefully within the next week or so ill get it started up so i can tear it all apart and get the brake lines done and save up for some bodywork and a paint job. Quote Link to comment
filthy forever Posted July 13, 2014 Report Share Posted July 13, 2014 B)coming along very nicely Quote Link to comment
