GORILLARILLA21` Posted October 24, 2013 Report Share Posted October 24, 2013 I took my master cylinder out a while ago and want to make sure I connect it up right. I switched to a 280zx master with maxima front calipers and wilwood rear disc brakes. What size brake lines should I run and is there a diagram to see where the lines connect to in the engine bay? Thanks a lot. Quote Link to comment
KlassicMotion Posted October 24, 2013 Report Share Posted October 24, 2013 The brake line size is 3/16" or 5mm... I can' tremember if it's metric or not. Take your master cylinder with you and make sure the line you buy threads into it. These are the best pictures that I have. Search some build threads for other pictures. Quote Link to comment
GORILLARILLA21` Posted October 24, 2013 Author Report Share Posted October 24, 2013 thanks a lot. Quote Link to comment
