LeX Posted August 18, 2008 Report Posted August 18, 2008 I am seriously considering a work VS-XX setup for my 510 wagon . I know i can fit the rear which would be 17x8 +22 as i have a huge bit of clearance back there currently. My concern is the front although I think i'll be fine. Front is 17x7 +22 and i am using the 280zx vented front brake setup with ground control coilovers. I really would like bigger wheels as the wagon is going to be pushing 14PSI on a Forced Performance 20G turbo on SR20DET with custom tuned ECU and all proper upgrades.. I was thinking I would like some more grip over what my 15s will offer me (they can go back over to my 4 door) anyone run bigger wheels like that with success? pic for reference Quote
69FJWagon Posted August 18, 2008 Report Posted August 18, 2008 those will fit I have 17's for my wagon to they are 17x7 front and 17x8 rear with a 35mm offset, with that said if you want your car to "hook up" dont go with a 17" wheel not enough sidewall on a 17" tire on a 510, unless your running a drag radial or something equal to a race compound tire I have a set of 16" wheels with Falken Azenis rt615s and with a 215-45 it still spins the tires when it comes on boost at 35 mph or so (in my 2 door). keep 15s if you can for the hook up factor but for the stylin factor 17s are cool :cool: Clayton Quote
240ADAM Posted August 19, 2008 Report Posted August 19, 2008 I had the same 17x7 front with a 4 inch offset and x8's in the back with 5 inch offset, it was dumped and fit purfect. http://a855.ac-images.myspacecdn.com/images01/64/l_321e1a5c0f2265196f8895748c992fde http://a181.ac-images.myspacecdn.com/images01/7/m_5bf662c7288be922f657cce668c3078c.jpg Quote
chumstone Posted August 20, 2008 Report Posted August 20, 2008 those wheels would look better than the ADR wheels on the silver wagon as they have more spokes. Mine have a pronghorn look to them. I have 35mm offsets and running spacers with adapters that have 4x100 bolt pattern. Quote
chumstone Posted August 20, 2008 Report Posted August 20, 2008 shot of front, 205-40-17 tires on the front. Quote
